z34 electircal problems
  • zeethreefour
    • Oct 2006
    • 15
    ok so like posted in another thread, i put a new alternator in last night, and bought new battery. when i started the car at the shop my engine light was on and now it wont go away
    the car started this morning and when i was leaving work my car wouldnt start...completly dead....also i was parked in the parkin lot pissin around and when i used powerwindows my rpms dropped and my heat wasnt blowing as hard, and my lights dimmed......lol wtf is goin on
    • 9191
    Probably didn't get all the connections tight or something... Or the new alternator is crap and not charging the battery.
    • Juglenaut
      • 1130
      Test voltage drop with voltometer from battery positive post to the positive AUX terminal with key in on position then do the same with the negative side of the battery to a engine ground or block. Aslo test voltage DC drop from battery positive to the AUX when a buddy is cranking, Do you get a large drop??
      You should get 0 on the nose volts DC from 2 points of commonality, common ground to a common ground: common power to a common power. Also check the alt or gen fuse, may also be possible that you blew a fused link.
      I am back
      Mechanical/Service Technican
