Couple problems
  • Carlspike
    • Oct 2005
    • 154
    #31
    From what you've said that code doesn't sound that serious, so I guess I won't worry about it. Time to find some cleens
    • grandprixgtp_91
      • Nov 2003
      • 758
      #32
      well it can be serious , all depends on whats wrong. but more than likey it shouldnt affect anything.
      Jake
      • Carlspike
        • Oct 2005
        • 154
        #33
        I bought some liquid top engine cleaner today, only cost 5 bucks. I've got a funnel that will fit in the small hole just before the TB so I'm going to try and pour it in there slowly. Hopefully the suction will be enough to atomize it as it goes in.
        EDIT: The pouring in tehcnique didn't work so well. I ended up trying to pour it in under the throttle blade and some got in but after I shut the engine down it started to run back out of the plenum. And I couldn't pour it in fast enough to get the engine to stall because it just poured back at me. However after letting it sit I did get a small white cloud so I may have done some good but I'm not sure. I guess I should just go with the spray. Anybody know if I can order some from GM and have it sent to a local dealer?
