Need Help setting Timing 3.4dohc
  • astros95
    • Feb 2007
    • 2
    I need some help with getting timing set on my 95 cutlass 3.4 Dohc, My Timing Belt broke at low speed. I've got engine taken apart to cams, I just dont know how to set those marking on cams and drive shaft gear. If anyone knows how please let me know Thanks. art
    heres a pic of what i got so far
  • grandprixgtp_91
    • Nov 2003
    • 758
    there is a very good walk through on this site that will give you exact locations and pics. but you need to replace the plastic pulleys and the metal tensioner looks bad too id replace it too. and from the looks of your timing gears the belt was riding off the side of the gears which probably caused premature belt failure, you should check for bent or warped items. http://60degreev6.com/showthread.php?t=24974 thats the walkthrough there, its very good, read it a few times , and look at it next to the engine, and if you still dont understand it then ask us , we' d be glad to help.
    Jake
