AIR check valve
  • series8217
    • Dec 2004
    • 387
    AIR check valve
    I just installed the AIR tubes on the rear manifold so I could get through smog. Brand new tubes with a brand new check valve... I don't have the AIR pump hooked up yet and noticed that I have an exhaust leak through the check valve at idle. Above 1500 or 2000 RPM it seals up. Should it be sealing at idle?
