No power steering?
  • J-Roc
    • Mar 2007
    • 5
    No power steering?
    Hi all,
    I just did my timing belt and the engine runs great. The problem that I'm having is that I do not have any power steering. The PS worked before I did the timing belt I took off the return hose and pointed it back into the cap/dipstick hole and when I run the engine, I can see the fluid returning into the ps pump. One note is that I did take apart to the ps pump to replace the seals. Nothing special, but maybe I overlooked something? Do I need a new PS pump? Any help or pointers would be greatly appreciated!
    -Jeremy
    94 GTP 3.4L, auto
    new timing belt and water pump
  • craftsman_454
    • Oct 2005
    • 24
    what did you take apart in the p/s pump?
    if you wanna see if you have any press. coming out of the pump, use a pair of large vise grips to gently pinch the high press line, you should hear the pump start to whine like your hitting a steering lock
    • J-Roc
      • Mar 2007
      • 5
      Would a failure of the rack and pinion cause a "no pressure" situation? I did have to move the car a few times and during those times the engine was not on, so I did not have any power steering whatsoever. Would this cause damage to the steering rack or p/s pump???
      94 GTP 3.4L, auto
