Ok I have heard a bunch of people talking about this shit Ive NEVER heard of it so I went up to Murrays Dicount Auto parts and they had that shit.. What is it sopost to do and how do you do it and is there a specific vaccum line u use when doing this on a 3.4 DOHC
SEA FOAM
SEA FOAM
1997 Chevrolet Camaro 30th Anniversary 5Speed.
3800 V6 (i know its not a 60degree)
stock for now
1993 Special Edtion/GTP
3.4 DOHC V6 LQ1 SOLD!
CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230Tags: None
It is supposed to clean out your engine. The longer the car smokes the dirty it is. I think it does a good job, but I am not sure if it wears anything down in the engine. You are supposed to put it in the brake booster vacuum line while the car is running. Might need a little funnel and make sure to pour slowly because the engine will shut off if you pour to much.
Once you poured the whole thing in I would let it idle until the smoke is about gone and then take it for a spin to get the rest out.
SEA FOAM
Do u use the bottle and should I expect the engine to stall when i pour it into the booster hose1997 Chevrolet Camaro 30th Anniversary 5Speed.
stock for now
Don't let the engine stall when you pour it in. If it sounds like it is going to stall. Stop pouring it in and then pour some more in.
I have heard for best results pour about half the can in..Let it run for about 5 mins and then pour the rest in and let it run again until the smoke is gone.
have you noticed a differnce after doing this, this reason why im gonan try it is, somtimes when i come to stop like removring in a parking lot or somthing the RPMS will drop bellow like 500 and almost stall n somtimes it will, seems like is does more when it is warm, I have replaced every vaccum line and ran some lucas fuel treatent in the tank and i have also used Tb cleaner in the intake.. u have any ideas1997 Chevrolet Camaro 30th Anniversary 5Speed.
stock for now
i have aslo replaced teh TPS and cleaned out the shaft of the IAC1997 Chevrolet Camaro 30th Anniversary 5Speed.
stock for now
I don't think seafoam will fix your problem. The GM top engine cleaner is similar, and I remember talk about that were you pour almost all in, let it stall and then sit... then later start up and pour the rest in. I would think that it could possibly clog your cat if all the carbon is broke free and blowing out your exhaust...
Anyone else have any opinions? Just from looking at my pistons from the spark plug hole they look pretty darn clean.sigpic
im having a whole new exhasut put on tommrow and im going to get rid of the cat seeing it prolly is clooged it has 140,000 on the car the engine has around 83,000. i think im rember reading on here once about fuel injecotrs in the 91-93 were bad or somthing and dont allow enough fuel after slwoing down froma crusie, ne one else have this problem?1997 Chevrolet Camaro 30th Anniversary 5Speed.
stock for now
Read my thread. Thank me later. It answers all your questions
http://60degreev6.com/showthread.php...637#post322637'93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
camaromanmatt@yahoo.com
If you can get the spray then use that, I used it on my 3.4 and it worked pretty good. It may not fix the problem you are having but it's always good to have a cleaner engine. Just start the car and get it warmed up, then take off the plenum. Use a small scredriver to hold the throttle open at around 1500 rpm's and start spraying it right at the throttle plate, a little bit at a time. When the can has about 1/3 left spray as much as you can until it stalls. Wait 15 to 30 minutes and restart it. You might need to work with the throttle a bit to keep it running. After it will run on it's own kick the rpm's back up to about 1500 and spray the rest of the can in it. Then go for a test drive and blow all the crap out of it.
