I need to find these REF Signals
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    I am installing an APEXI NEO on my 96 GTP.
    I need to find these signal references for the inputs so I figured that someone here would have a quick reference for me.
    Here is what I am looking for:
    RPM Signal
    Throttle Signal
    Airflow signal
    Thanks
    I dont know what this means but "ASS HATS" is funny
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    I am wondering if anyone would know on the 16PIN OBDII Connector which pin gives these three informations?
    ANyone know who might know?
    • OldSkoolGP
      That guy over there
      • 930
      Only 4 pins on the OBDII are wired. All the data from the ECU comes over 1 pin via a serial bus, so you can't go there. If you can get your hands on a service manual they detail which wires do what and what you need to splice in to to get get your signals.
      • Identity Crisis
        Lost at Birth
        • Jul 2006
        • 295
        I have a haynes manual. I tracked down the wires but I think they are all underhood and I want to attach under the dash.
        Thanks
        • OldSkoolGP
          That guy over there
          • 930
          You can't. MAF and airflow signals dont run inside the car because it's not necessary. you have to splice off the wiring for the engine harness.
          • Identity Crisis
            Lost at Birth
            • Jul 2006
            • 295
            Thats what I was figuring.
