Cleaning the MAF?
  • novastique
    • Apr 2007
    • 11
    Cleaning the MAF?
    Starting a new thread here, so i get the stuff in a more appropriate category.... quick rundown...Got the '96 monte for a song, , fixed cam timing, still wasn't running quite right. Borrowed a friend's scanner, popped a bunch of codes, so i cleared them, and presto! Like throwing a switch, it ran 100% better! Sweet! After a bit, however, 106 and 300 popped up. After doing a bit of looking around, it seems the MAF is probably the root cause...anyway, I saw while i was looking around that a guy cleaned his...but didn't say what he used to clean it. I see o'rielly's has CRC (brand name?) MAF cleaner...is this stuff okay, or is there something else i should be using instead? Or should i just not be so cheap and drop $110 on a new MAF?
  • thestoned0ne
    • Jun 2007
    • 10
    Def try cleaning it first....Just a simple cleaning can do wonders.
    • 93Oldsdroptop
      • 167
      Use the CRC MAF cleaner--it works great and will not damage anything.
      '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
      '06 Dodge Magnum SXT 3.5L -- My Daily Driver
      • novastique
        • Apr 2007
        • 11
        ok, thanks for the tip. Tried the CRC MAF cleaner, no change. So, in with the new MAF, cleared the codes, and....its better, but still not right. Same 106 code, but instead of "mass airflow voltage range performance problem" or something like that, it gives the same code, but says "manifold absolute pressure/barometric pressure voltage range performance problem" I'll admit my memory ain't the best....I'll try the new MAP tomorrow.....
        • novastique
          • Apr 2007
          • 11
          When it rains, it flippin pours... On the way home from the parts store, to get the MAP, the engine decides it doesn't like the #2 spark plug....so it spits it out....time to rethink this whole thing.....
          • novastique
            • Apr 2007
            • 11
            New MAP sensor made no difference in how it ran, throws the same code. p106 and p300 DAH!
