284 5-speed oil leak
  • crazyd
    • Mar 2007
    • 100
    Looks like it's coming from the driver's side diff where the halfshaft attaches to the stub axle. Is that a seal that can be replaced with a 282 part? Also, do the output shaft support bearings for the 282 work on 284's?
    92 ASC GTP - 3.4 5sp, HUD, DIC, AQ9's
    88 Fiero GTs - L32 3.4 5sp & ZZ430 5.7 SBC V8 5sp (the twins) L32 -> LQ1 swap is underway
    6sp LS1 Corvette Roadster (parts getter)
    '99 Expedition (tow truck)
    '09 G8 (new toy)
  • MONICAZ34
    • 111
    are you sure its oil and not synchromesh fluid?
    • crazyd
      • Mar 2007
      • 100
      Same thing. Point is it's leaking fluid, doesn't matter what kind.
      '09 G8 (new toy)
      • pwmin
        • Aug 2004
        • 394
        gm part number is 14092900 (discontinued)
        you can order some and wait or call up a parts store and see if they can interchange them. i think theres an a/m pn in one of the recent trans section threads. i found some seals from another tranny that worked, but im not sure what they were. they actually were a little tighter than the gm ones. i think they were actually from like a 60.
        edit: found the post but there was no number in it.
        91 GTP HM-284 GONE :(
        98 Spawn of Satan (L67 Regal)
        87 V10 SM-465/Mild 350
        06 Cobalt SS/SC GONE :(
        • crazyd
          • Mar 2007
          • 100
          Using that I found AC Delco part number 24202835 Drive Shaft Seal which says it's for the 3- and 4-speed automatics, though it is also listed under Manual Transmission. If it's the same part number that'd be great, as it seems to be pretty commonly available. There's also a Timken part number 3543 listed as an Output Shaft Seal.
          '09 G8 (new toy)
          • OldSkoolGP
            That guy over there
            • 930
            The part number you need to get from the dealer should say that's its discontinued from GM but that you can get them from VPI. I had to get two of them earlier this year, they have about 430 left.
            • crazyd
              • Mar 2007
              • 100
              Last time I called VPI they wanted $500 for a $50 part!! They're not my friends anymore.
              '09 G8 (new toy)
              • series8217
                • Dec 2004
                • 387
                Even if the output shaft support bearings work on the 284, I wouldn't use them. The surface they ride on is NOT hardened. The axle surface gets galled.
