no power, no SES light, need some help
  • batou
    • Aug 2007
    • 4
    Hi, I have a 92 z34 3.4 with auto.
    couple days ago I was leaving home for work and while going up the street, it lost power like somebody flipped a switch. to the point i have to floor it and down shift whenever i want to accelerate.
    The car seems to be running ok until you drive it, meaning it idles fine, maybe a couple hundred rpm lower than usual but it sounds ok.
    whenever I test drive it smokes a bit from the undercarriage, seeming to come from the exhaust, thats why i checked the cat.
    I have replaced the egr valve, tps, iac, and checked the cat (ran open headers up and down the street.. neighbors gave funny looks).
    It has never displayed a ses light, when I pulled the codes all i got was a code 35 (iac) which I then changed out and it did not make a difference.
    I have found one broken vacuum line that goes over the brake booster and along the firewall as a rubber line then transfers to a plastic line... which has melted through from the heat from the exhaust, so i have no idea where it goes to, i think it had a 90degree connector at the end of it, I saw it hanging loose when i changed out my high pressure line, couldn't find where it went then either.
    At this point I am lost as what to look at next, what really boggles me is that there is no ses light and it idles fine, if not a little low, it doesn't seem to have a miss and it doesn't smoke at all, oil looks good too.
    Thanks for the help.
    • 9190
    I'd look into your coil packs and then possibly your ICM. But running good at low RPMs but crappy out up high sounds like coils to me.
    • batou
      • Aug 2007
      • 4
      well I looked into it a bit further. Seems I did not have spark on cyl 2 and 5, so I replaced that coil... but I still have no spark. Any ideas? is there a fuse that I cannot find that controls just that coil?
      Thanks
      • batou
        • Aug 2007
        • 4
        anybody?
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          most likely Ignition Control modual
          swap them around and see if the dead cyl follow the coil, or if its allways that 1 spot on the ICM
          just keep track of how your firing order is :P
          • batou
            • Aug 2007
            • 4
            Is there a way to test the ICM? I dont want to spend another 100$ without being sure.
            Thanks again
            • Eric's93z
              • Jul 2006
              • 23
              Iam Thinking Its Your Fuel Pump......my 93 Z Did The Same Thing.....was Driving Fine Then The Next It Lost Tons Of Power, Actually Had None.
              • pontiacdohc@gmail.com
                Pontiac DOHC
                • Feb 2006
                • 181
                yes, just about any auto parts store can test ICM and i know they can test that one because they tested mine.. I was running into the same problems i thought it was the icm also but it tested good, it ended up being a bare wire that pluged into the ICM, if it is bad get one from a junk yard and it the store and get it tested too before u put it on
                1997 Chevrolet Camaro 30th Anniversary 5Speed.
                3800 V6 (i know its not a 60degree)
                stock for now
                1993 Special Edtion/GTP
                3.4 DOHC V6 LQ1 SOLD!
                CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
                180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
                VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
