Timing belt issue.Help please!!!
  • thestoned0ne
    • Jun 2007
    • 10
    I have just finished reinstalling my heads after having them rebuilt.
    Timing belt is installed and I am trying to time the cams.
    Problem is that when i go to turn the engine over to get the rear cams flat it seems to be binding.
    Rear cam tool is removed before anyone asks that, and I have the gears on the front loose and free spinning.
    What can be causing the resistance????
    I removed the rear carrier and inspected the lifters...looks like I have three that are collapsed, so thats prob my problem....
  • napatiger
    • 490
    What yr car?
    my experience with 95 MC...
    I would not use the starter to rotate the engine, if that is what you mean by turn it over...
    No oil pressure would bind the camshafts in about a minute and a half of idle, don't ask how i know.
    Sometimes the lock ring will lock with out the bolt being tight.
    Good luck.
    95 MC Z34 Black
    • thestoned0ne
      • Jun 2007
      • 10
      Its a 95
      I was turning it over by hand...would not attempt with the starter as I was timing the cams.
      I believe the problem is what started all of my problems originally.
      Found three bad lifters on the rear bank, that are more or less collapsed/siezed that was preventing the cams from turning. So now I have to get new lifters. Trying to decide whether I will go back with OEM and only replace the bad ones, or get a new complete set of aftermarket ones.
      Cant believe how much they want for a full set of stockers!!! That is crazy...30-40 a pop.
      • Coyote_Rage
        Wrench Jockey
        • Mar 2007
        • 115
        When I was working for AutoZone I priced a set for 16 was 740 bucks!!! Advance carries the stock set for 60 ish for 24
        • thestoned0ne
          • Jun 2007
          • 10
          I know!
          The price is stupid high on the damn things! I dont recall Advance having a full set for around 60 bucks though......
