I've noticed that when I take my car WOT, I usually get a smell of burning oil from the heat in the vents. I am pretty sure I have the o-ring leak, so my guess would be that it is somehow leaking down onto the exhaust manifold. Another issue is when I go to start it in the morning, if I don't let it idle for 2 or 3 minutes, it will misfire and stumble really bad unless the pedal is at least 2/3 the way down. Is this a surefire way to know that your intake manifold gasket(s) are shot? My last issue is that whenever I turn on my blinker, I notice that all the lights on my gauge cluster dim and brighten, with the blinker. I have an SES light for the egr code and my ABS light is on as well. They both brighten and dim a lot with the blinkers. I don't seem to have any other issues with electrical in the car. No headlights dimming, I have a small weak system in the car, and nothing dims with the bass or anything.
Burning smell... among other things.
Tags: None
W-Body Forum answer.
Long story short, it is your aux positive battery terminal. It will be getting hot and all the symptoms are exactly the same as the one in the forum post above.
but what causes the burning smell?? cuz i get a smell from my vents like right before/while/and after the thermostat opens.. also i have smoke coming out of my vents and i believe the blower motor is buring up b/c it only does that when the motor is on.. wierd..
But what causes the burning smell???Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
