LQ-1 Electrical Problem
  • VerbotenZ34
    • Dec 2003
    • 133
    Okie dokie, everything's done back up and runs like it did before - perfectly
    I was going to take a picture of myself giving the finger to the old alternator(just like in the 60*V6 instructions ), but forgot before I took it back in to get my core refund. I just want to say that Ben's walkthrough was great, and really helped a noob like myself out. It's probably the biggest job I've tackled yet, but it went off without a hitch (once I got past the bolts)
    Verboten
    \'92 Lumina Z34: It\'s not unmodded - It\'s Super Stock!
    • bud36light
      • Nov 2003
      • 517
      Lyle's GTP your right. Long as you can use heat or other means the red stuff will work. Just have to be careful where you use it. I generally use the blue stuff if thread lock is needed.I once worked for 2 days loosening a nut on a steering nuckle where it was used. Then again after thinking about it I wasnt the person who torqued the nuts down either.
      2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
      • Lyle's GTP
        • Jan 2004
        • 1345
        I did an oil change on a buddy's '97 Honda Accord. He always got the dealer to do it. Shit, when I tried to remove the oil plug, a pair of snipped wrenches wouldn't even budge it. I had to use a 1/2 inch impact wrench to loosen it, not to mention it took about 30 seconds before it would break loose. I'm guessing they torqued it to about 120-150 lbs. Spec. was 30 lbs. Dumb Fucks.
        Lyle
        • VerbotenZ34
          • Dec 2003
          • 133
          Wow, that's incredible
          In fact, so incredible, I don't believe it :P
          J/K Verboten
          • Lyle's GTP
            • Jan 2004
            • 1345
            Believe it! Fuckin' dealers, just like Siagon Whores. Either to way too tight or way too loose! Just Playin'
            Lyle
