Ignition System
  • Lyle's GTP
    • Jan 2004
    • 1345
    Ignition System
    Hey Guys, could some body let me know the circuitry of my 94 grand prix's ignition. From battery to key to starter and any relays in between. Also possible locations of them. Scimatics would be great. Thanks
    Lyle
  • Juglenaut
    • 1130
    Diagram
    Diagram 1994-95 Vin X[/img]
    I am back
    Mechanical/Service Technican
    • Lyle's GTP
      • Jan 2004
      • 1345
      Thanks, that's awesome.
      Lyle
      • Lyle's GTP
        • Jan 2004
        • 1345
        Hey guys, looking at this could the theft deterrent relay cause my car not to turn over. Or is it usually the ignition switch? Keep in mind that I have put in 2 new starters and it still does the same thing. But the old one never did this. When you turn the key, the selonoid clicks but it won't always engage. Some times it takes twenty tries.
        Lyle
        • 4spdz34
          • 185
          from your last response it sounds like high resistance in the starter wires. have u done a voltage drop on the wires?
          • Lyle's GTP
            • Jan 2004
            • 1345
            Do you mean the primary from the battery to the starter. I checked all the connections twice and cleaned all the terminals. But like I said the old starter never did this, only the new ones. The car cranks strong, it just doesn't engage all the time.
            Lyle
            • Mitch DOHC
              • Jan 2004
              • 261
              my 94 cutlass did that the problem that i had was that the... i guess u would call it the axuliary battery terminal was messed up... and not making a good conection.. i got another one from a junk yard and it fixed the problem
              1994 Cutlass Supreme Convertible 3.4 DOHC
              1969 Oldsmobile 442
              1997 Chevy Tahoe
              http://members.cardomain.com/mperkins442
              • Lyle's GTP
                • Jan 2004
                • 1345
                Wierd. My auxilary terminal goes to the battery, but then the terminal has another wire to it, that wire goes down to the starter and then to the alternator. It doesn't sound like your setup is the same as mine.
                Lyle
                • bud36light
                  • Nov 2003
                  • 517
                  Lyle's GTP Hey man I got a similar problem. Posted a topic about it and only got like one reply. I replaced my battery cables and it hasnt failed in at least a week where as it was screwing up every 2-3 starts. Warning dont go to the dealer. They want $100. Got mine at NAPA for $30.
                  2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
                  • Lyle's GTP
                    • Jan 2004
                    • 1345
                    Thanks, I'm going to do custom wires anyway so I will get the project underway.
                    Lyle
