What are the cylinder & coil terminal locations on my 93 Z? Thanks.
Cylinder and coil terminal location on 93 Z/34.
What? Your coils are under your front header and the spark plug terminals are on the spark plug boot deep inside the top of the head.
it is 1,3,5 on the back. 2,4,6 on the front. and on the coils it is top row 1,6,2 the bottom row is 4,3,5
Carefull with 2 and 5 they are a little tite and can get mixed up easily.
top row and bottom row?
all the coil terminals are in 1 row.
if you have gm coilpacks they should be numbered, also there should be a black sticker in your engine bay that denotes the terminals.
iirc it is 1,4,6,3,2,5.The Official Rotating Mass Nazi
Cylinders are numbered starting at the front (pulley side). From the front pulley on the motor, the cylinders are 1 2 3 4 5 6 alternating banks, starting at the bank closest to the front of the motor. Note that this is true for all engines.
