Coolant Temperature Issue
  • 5speedz34
    • 301
    I just got the GP running and its been doing this long before it was just taken in.
    The gauge on the dash usually stays below 210 once it warms up. Once I get to a traffic light though the needle moves up usually somewhere between 210 and 235 (the halfway mark between 210-265). Once I take off the car starts to cool back down. It stays pretty stationary while moving.
    Whats the deal?
    New Radiator (aftermarket, looked to be a little thinner than stock)
    New W/P
    New hoses
    New T-stat
    Fresh coolant
    Both fans work.
    FWIW: The primary fan comes on at 230*
    Heres what the cluster looks like:
    1992 Lumina Z34 | 3.4L 207ci DOHC 60º V6; Getrag 284 |
    1994 Pontiac Grand Prix GTP | 3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E |
  • 93Oldsdroptop
    • 167
    That sounds pretty normal to me. That's what my Olds does and has done since the day I bought it.
    When you sit at a light, the coolant doesn't circulate as fast and there is no air blowing thru the radiator. Then when you go, the flow increases and the radiator gets cooled.
    That's why your temp goes higher when standing at idle in D.
    As long as it doesn't get higher than around 235, you're ok. That's why your fans are set to kick on at 230 degrees.
    '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
    '06 Dodge Magnum SXT 3.5L -- My Daily Driver
    • gpse3400
      • 1460
      The pushrod engines got a thinner radiator in '94 I beleive. The TDC had the same size core since '91. So it is quite possible you are running a pushrod radiator and that's why the engine is geting hot. Verify this.
      Lorenzo
      • 5speedz34
        • 301
        My buddy got the radio for me from NAPA unless for some reason what NAPA lists is wrong.
        EDIT: It did basically the same thing with the old radiator.
        • gpse3400
          • 1460
          Was the old rad clogged?
          Lorenzo
          • 5speedz34
            • 301
            No it was leaking slightly from the driver's side tank, above the upper radiator hose. The leak wasn't the problem, but the cooling system wouldn't pressurize.
            • gpse3400
              • 1460
              Are you running that new style waterpump with the sheet metal impeller?
              Lorenzo
              • 5speedz34
                • 301
                The impeller are the "blades" right? If so then yes. I looked kinda cheap to me.
                • Carlspike
                  • Oct 2005
                  • 154
                  I had problems with the updated style water pump. After I put the new style on the car it would go almost into the red at stop signs and on coast down. After replacing the new style pump with a reman one there has been no problems, the car runs at 210 all the time. I'm not sure if I just got a bad pump but the new style didn't work in my car.
                  • gpse3400
                    • 1460
                    that pump works for the pushrod engines, its not ment for the TDC, you should get a reman old style or got the yard and yank one off any GEN2-3 60 deg V6 from '03 down.
                    Lorenzo
                    • 5speedz34
                      • 301
                      Damnit.....
                      • series8217
                        • Dec 2004
                        • 387
                        Huh, I haven't seen this "updated" water pump yet, but mine is about due for its 15,000 mile interval replacement (they don't seem to like the revs much do they?) as it has some play in the bearing now. I'll have to watch out when I get a new one. I guess the manufacturers ran out of new cast iron impellers?
                        • gpse3400
                          • 1460
                          I dont know what the deal is... The spacing may not be right from the impeller to the TDC housing or its is just cheap pos. I've never seen it either but i know this engine doesn't like using it. Of all the w bodies and engines I've owned, I've never had a problem with the water pump except once and that was my first car.....
                          Lorenzo
                          • 1994KlrWhaleOlds
                            Professional misanthrope
                            • Jan 2008
                            • 156
                            • series8217
                              • Dec 2004
                              • 387
                              Thanks for the pic!
