1992 Lumina z34 wont start.
  • Rabbi
    • Jun 2005
    • 110
    update : Tried a junkyard coilpack from a running vehicle, Still no spark.
    Will be trying a brand new crank position sensor tommarow.
    Gonna rent a compression tester as well.
    will report my compression #'s tommarow
    also, does anyone know the wire routing for the ignition system?
    gonna try to trace my wires and make sure i have no break in the wires.
    • Rabbi
      • Jun 2005
      • 110
      also i previously stated the tach did move when cranking the car, it does not move =(
      i guess i got confused, The tach moves only when i turn the key to the on position for a slight second. When cranking the car over the tach stays dead still.
      • Rabbi
        • Jun 2005
        • 110
        CPS is in, SHE SPARKS!!!!
        just gotta get the upper intake on and im finally done with this dreadfull project lol.
        thanks a ton everyone for the help.
        • Juglenaut
          • 1130
          Hmm the mem-cal chip should have went into a secondary mode??
          For some reason CAL set was not saved or recalled, the ECM didn't remember cylinder one TDC and bank learn and timing advance, your ECM may need a new mem-cal EEprom or attempt a reflash.
          I am back
          Mechanical/Service Technican
          • Rabbi
            • Jun 2005
            • 110
            what do you mean?
            • Juglenaut
              • 1130
              #21
              In other words, I would have your ECM checked.
              It may test good but may not recall any faults or store intergers correctly, the little chip thing that plugs into the ECM may have a problem if you can not get codes or a SES light in normal run from the ECM when there is a known fault like pulling the IAT (intake air temp) sensor.
              I am back
