Proper Compression #'s???
  • Rabbi
    • Jun 2005
    • 110
    what is the proper compression on the 3.4L DOHC?
    gonna check for compression tommarow, Just curious as to what the compression spec's should be?
    Thanks
    • 9191
    Usually anything above 150 is ok. You want the numbers to be within 10% between all cylinders. So if your lowest cylinder was 150psi, then you shouldn't have any cylinder higher than 165psi.
    • RedZMonte
      • Feb 2004
      • 1378
      cool, thanks man!
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
      • gpse3400
        • 1460
        they should run about 170-190 psi
        Lorenzo
