SOOO MUCH SMOKE AND BURNING OIL!!! ahhh! help!
  • CoreyJ
    • May 2008
    • 5
    Ok i have just about run out of ideas guys. I just bought my 94 lumina z34 and the previous owner said the timing belt had just been done but ever since that day oil has just been pouring out and burning on the exhaust manifold. so i thought it was the infamous o-ring leak. I went ahead and fixed the o ring leak with lots of RTV sealant and some J B WELD. but it turns out that WASN'T the problem... grrrr.
    The oil is literaly pouring out a Quart every 5 miles and some burning on the rear head manifold.
    so i know for a fact the oil is coming from somewhere on the pulleys side of the motor (passenger side) around the rear head or firewall side.
    i wish i had a lift so i could get a better look because im not taking that intake manifold off again.
    i have done some diag. to test for head gasket blown. and there is no oil or coolant in exhaust gas and the oil is not milky and the coolant is fine.
    What do you guys think? Oil pump? Odd head leak? cam carrier?
    Please respond i have only about a week or 2 to fix this oil leak.
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    pics would help to see what you are seeing...
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    • 55trucker
      • 213
      Have you tried removing the plastic shroud access cover from the rear head to get a look into the area around the camshaft drive gears and the seals there?
      91 LQ1 GP GT
        I've had mine leak from the gasket between the cam carrier and the head before.
        • CoreyJ
          • May 2008
          • 5
          Not yet.. but i will take a look tomorrow afternoon.
          Was there a stream of oil as mine is?
          ill try to get some pics later.
          • z34phoenix
            • Jun 2005
            • 469
            maybe that cover in the valley? the one that covers the dummy shaft thingy. lol
            • CoreyJ
              • May 2008
              • 5
              that may be.. is this common to have leaks? man looks like ill have to take all that stuff off again. at least i can reuse the new gaskets in there
              • OldSkoolGP
                That guy over there
                • 930
                If the timing belt was just done, I wouldn't be surprised if the guy that did it removed the rear cam carrier thinking he had to to loosen the rear cam cogs. Then he put the rear cam carrier back on, and either didn't use a new crush gasket between the cam carrier and the head, or he forgot to put one on altogether. I'd bet anything that's the source of your leak, which means replacing the cam carrier gasket, which also means you have to do the cam timing again. A good way to check is to remove your rear spark plugs and see if they're covered in oil.
                • SuzukiGhostRider
                  Beretta Freak
                  • Apr 2008
                  • 118
                  I was thinking the same thing as OldSkool. You either have a missing or re-used cam gasket. GL.
                    I wouldn't say a stream came from mine, but it did leak way more Mobil 1 then I cared to go through at the time. It was smoking a bit on shut down, but if I had to throw a number out there I would say it was a quart or two a week, and I didn't live that far from work. So at that point, I bought a head gasket set and Ben and I tore it down. Ben mentioned we weren't far from removing the heads at that point, so those came out and got touched up with a Dremel compliments of us for the next two days or so. BTW, Dremels suck for porting heads, lol.
                    • 55trucker
                      • 213
                      All in all.....a case of cleaning up someone else's mess?..That's depressing...Is it possible this is the reason why the previous owner let the car go?...
                      91 LQ1 GP GT
                      • CoreyJ
                        • May 2008
                        • 5
                        im pretty sure your right.. the previous owner said she was just tired of putting money into it. but im not complaining too bad because i only paid $350 for it
                        • CoreyJ
                          • May 2008
                          • 5
                          Ok guys im about to get rady to tackle this job of pulling the rear cam carrier off. i reached back there and felt where the head and cam carrier meet together and my fingers were covered in fresh oil as if there is no gasket there.
                          soo.. when im doin this job do i have to re-do the timing? or can i some how just mark the cam gears and the timing belt and then loosen the tensioner and slide the belt of then pull the cam carrier and install new gasket. then slide the belt back on and align with the marks tighten the tensioner back and reinstall bolts and call it a day?
                          • 55trucker
                            • 213
                            Well to make your timing the cams easier you really should have the cam lock down tools (2, one for each head) to *lock the cams into place after you bring #1 up to top dead (before you pull everything apart), without that tool you're really in a bad state. Trying to hold the cams by wrench or socket and get them in the right location to slip the timing belt back is nearly impossible to do.
                            91 LQ1 GP GT
