Favorite Spark Plugs of the 3.4L DOHC Monte Motor
  • Danspeed1
    • May 2006
    • 86
    Hello,
    I have a 95 Monte Carlo Z34 w/ 3.4L DOHC Engine. I am just doing a little late "spring cleaning," and am looking to change the spark plugs. Currenly I am running standard 30K A/C delco copper prong spark plugs.
    I just wanted to find out before i go and replace it with the same ones if there is a favorite for this engine? Anything this engine runs better or longer on?
    Dan
  • 3100 MPFI
    • 1522
    Don't get anything BOSCH. I use Delco Rapidfires.
    Taylor
    1998 Lincoln Mark VIII
    • Identity Crisis
      Lost at Birth
      • Jul 2006
      • 295
      AC Delco all the way.
      I dont know what this means but "ASS HATS" is funny
        I'll second the Rapidfires.
        • Danspeed1
          • May 2006
          • 86
          Thanks guys,
          Dan
          • z34phoenix
            • Jun 2005
            • 469
            personally i have seen too many stock engines runing lean. prob from the fact that these motors are plauged by vac leaks. in any case i would run a slightly leaner plug then stock. it is for this reason i cant run rapid fires any more they dont have them in the correct heat range i now run autolite AP-103's two heat ranges cooler. but for the adverage dohc'er i'd recomend the ap-104 the double plat in the autolite isnt worth it. go with the cheeper single plat and just swap them out.
