Some Backfiring/knocking - suggestions
  • grandprix34
    • 168
    When i hold the acceleration to 3k in idle (ffp chip/removed limiter) i start hearing and feeling backfiring through the exhaust...then when i let the gas pedal go, I'll here backfiring (or knocking) in the engine compartment...
    -spark plugs are new
    -wires are new
    -ICM was replaced awhile back
    -ECM was also replaced wit a 94 Lummy one
    Is this a case of a coil or crank sensor going bad or is it a serious "need to rebuild" engine case? Ill take vid/sound if anyone will host it...
    by the way, i just ordered an ALDL cable and downloaded the Freescan software to use with my notebook computer.....what parameters should i look for that are out of wack?
    _________________
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
  • brian89gp
    • 554
    Probably cause you're doing it in neutral. This motor runs horrible unless it is under load.
