Spun a rod... how to remove crank for machining?
  • crazyd
    • Mar 2007
    • 100
    I spun the #1 rod bearing and upon reassembling it with fresh bearings and checking the clearance, got a .076mm which is a good bit past the limit of .062mm. I checked another one and got a .040mm. I obviously need to get the crank machined and have a couple questions.
    1. How do I deal with the timing chain that connects to the main timing pulley? Is it a balanced shaft that needs to be realigned with the crank, or can it just be reinstalled anywhere?
    2. Should I have all the journals machined, or just the spun one?
    Thanks,
    Dave D
    92 ASC GTP - 3.4 5sp, HUD, DIC, AQ9's
    88 Fiero GTs - L32 3.4 5sp & ZZ430 5.7 SBC V8 5sp (the twins) L32 -> LQ1 swap is underway
    6sp LS1 Corvette Roadster (parts getter)
    '99 Expedition (tow truck)
    '09 G8 (new toy)
  • crazyd
    • Mar 2007
    • 100
    Decided to get a reman crank w/new bearings instead of machining this one. Question remains, is there anything to know about the chain that connects to the timing gear?
    '09 G8 (new toy)
