Secondary Air Injection Trouble code Help
  • DJ
    • Apr 2004
    • 3
    Does the code mean replace
    EGR : Exhaust Gas Recirc Valve
    Oxygen Sensor
    or does it mean somthing else?
    96 Olds Cutlass 3.4
  • Cotton
    • Feb 2004
    • 33
    it means the electronic A.I.R pump has a problem, check fuses, check the hoses on the pump for water intrusion (if there is water, new pump), check if the pump builds pressure, remove outlet hose and put your thumb over it.
    What code do you have exactly? P0410?
    proud supporter of \"W\"
    • 4spdz34
      • 185
      there is a recall on that go to the dealer
