Chevy 3.6L V-6 Oil Change
  • wksracing
    WKS RACING
    • Sep 2008
    • 3
    Does anyone know any specifics about changing the oil in the subject motor?
    I have done hundreds of oil changes, but never on this engine. I was just wondering if there were any tips or hints out there.
    Thanks,
    WKS
  • Nightingale
    • Apr 2005
    • 259
    I work at an oil change and I just did my first 3.6L. Nothing special about them. Only thing as it was an acadia and it was a real pain as the filter is mounted below the exhaust manifold. So not only can you not get a visual, but if its been run all day like in my case its also super hot. Also I had to get the filter from up top under the hood, not down below under the car. Just depends on what car your doing the change on, wether it'd be a caddy, g6, acadia, malibu, etc.
    98 camaro swapping in lz9 th400 setup
    LZ9 specs: (Subject to Change work in progress)
    4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
    • wksracing
      WKS RACING
      • Sep 2008
      • 3
      Thanks for your reply Nightingale....your info helps...one quick question: Is the oil drain plug on the bottom of the engine near the exhaust pipe(s)? I think I see it, but I just wanted to make sure.
      Let me know.....thanks again!
      WKS
      • wksracing
        WKS RACING
        • Sep 2008
        • 3
        PS: Your 1990 yellow Indy car sounds great.
