Bolt that holds the timing belt tensioner pulley???
  • grandprix34
    • 168
    anyone know if the bolt that holds the timing belt tensioner pulley is the same size and length as the one that holds the idler pullies??
    I Managed to strip it while doing the 13* retard timing...now i have no car
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
  • grandprixgtp_91
    • Nov 2003
    • 758
    I am almost positive that they are the same. make sure you didnt strip the hole and not the bolt because then you will need to tap it over and buy a bigger bolt.
    Jake
    • Juglenaut
      • Dec 2003
      • 1130
      BOLT MATCH!!!!!!!!!!
      I am back
      Mechanical/Service Technican
