ticking sound in the grand piece.
  • jwakamud
    • Oct 2008
    • 12
    i can best describe it as ticking. coming from the engine, and the longer the engine runs, the more pronounced the ticking gets. and its gotten worse over the last 2 weeks or so. initially i could only barely hear it while idling, now i can hear it most of the time once the car warms up.
    video link:
    i tried to get rid of as much background noise while filming, i took about 7 total recordings, but my sound on my computer has decided it no longer wants to work -- so i cant edit any of them down. this one seems to be the best.
    you might not even be able to hear it, but thanks for looking, if you do.
    any idea what it is?
    (1995 Grand Prix 3.4L) (probably wrong topic, sorry)
  • GTP091
    • Jun 2005
    • 232
    I can't make out any ticking. Maybe you could record from the engine bay instead of in the car. Have you checked your oil??
    • bve32k
      3.4 DOHC FTW
      • Jun 2005
      • 475
      Can't hear any ticking sounds in the video. Like the post above said. Check the oil level and possibly check the tranny fluid level make sure they are correct.
      • 55trucker
        • 213
        Purchase yourself a stethoscope....they are not expensive and are useful when trying to locate hard to hear sounds/clicks/noises that one can't pinpoint with just your ear.
        91 LQ1 GP GT
        • jwakamud
          • Oct 2008
          • 12
          video of the ticking
          • bve32k
            3.4 DOHC FTW
            • Jun 2005
            • 475
            Originally posted by jwakamud View Post
            Almost sounds like a lifter tick. Usually you can hear the lifter's ticking if the oil is low.
            • jwakamud
              • Oct 2008
              • 12
              oil level should be fine, just changed it not too long ago, and no leaks. ill check it tomorrow to be sure.
              if its a lifter, how urgent is it to get fixed? and how involved would it be for me to fix it? i assume itd be around or over $1k to pay a shop to fix it . . .
              oh, 129000 miles.
              • bve32k
                3.4 DOHC FTW
                • Jun 2005
                • 475
                oh, 129000 miles.
                Lifter tick really isn't urgent thing to fix. Mine use to tick all the time. Usually just means they are not getting as much oil up there as they should. I started using different oil to get rid of the ticking.
                What grade oil are you using? and what brand?
                • jwakamud
                  • Oct 2008
                  • 12
                  mobil clean 5000
                  someone told me this car doesnt have lifters??
                  • bve32k
                    3.4 DOHC FTW
                    • Jun 2005
                    • 475
                    mobil clean 5000
                    Yes. This car has 24 lifters. Whoever told you must not know to much about the 3.4 DOHC. Are you using 5W-30?
                    • jwakamud
                      • Oct 2008
                      • 12
                      10W-30.
                      • bve32k
                        3.4 DOHC FTW
                        • Jun 2005
                        • 475
                        10W-30.
                        hmmm..I have the light weight lifters in my car so I am used to hearing them tick a lot. What I have done to not get them to tick so loud is I started using Castrol Syntec 5W-40 which has helped a lot. It may not be the oil for your car, you may actually have a collapsed lifter that is ticking, but I could be wrong.
                        • jwakamud
                          • Oct 2008
                          • 12
                          how could i tell the difference between a collapsed lifter and benign ticking?
                          and thanks for the input so far, from everyone whos contributed
                          • bve32k
                            3.4 DOHC FTW
                            • Jun 2005
                            • 475
                            Only way I know for sure to tell is to take it out. Once you have it out try pushing on button in the middle. It should be hard to push it down and if you let go it should pop back to normal.
                            Here is a pic of what it looks like. The little button in the middle is what I am talking about.
