o- ring... help!! 92 cutlass supreme 3.4 dohc
  • Jewelnohio
    • Apr 2004
    • 11
    The dist. oil pump drive o- ring is leaking like crazy . I read the post about grinding the head to remove the cover without removing the head . how much clearance is needed to replace the o -ring ? Is the jb weld fix a viable option to fix this problem . Please help !!!!
  • 93Oldsdroptop
    • 167
    Instead of grinding the head, grind a notch in the plug head about 1/8 inch or so. This will allow you enough room to pry it up about 1/4 inch or so. Then get yourself a couple of old Chevy distributor gaskets, slice them and fish them under the plug with lots of Hi-temp silicone sealer. Make sure the slices on the gaskets are opposite. Ensure that you spread the sealer all around by turning the plug when it's wet. Button the whole thing up and let it sit overnight minimum.
    Did this to a 92 3.4 last year and it is dry as a bone to this day. Granted, it's taking the cheap and easy way out, but compared to pulling the head, etc., it's a viable alternative.
    Good Luck!
    '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
    '06 Dodge Magnum SXT 3.5L -- My Daily Driver
    • Jewelnohio
      • Apr 2004
      • 11
      Well , I did it !
      Couldn`t get a couple of dist. gaskets locally today , so I got some gasket material and made my own . Put the ultra black Hi - temp sealant on them , and snugged her down . Still waiting for sealant to cure will let you know the results . Thanks to 93oldsdroptop for the help !
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Lemme know if it works. I got the same problem, but not as bad. That is a good shortcut. Almost as good as the 20 minute plug change.
        • Jewelnohio
          • Apr 2004
          • 11
          It`s working Great !!!
          Well .... It`s working so far. No signs of any oil leaks at all . I only had about an 1/8 " clearance from the head and I didn`t do any grinding at all . Just lifted the drive cap up and slid the gaskets under it with the sealer . Thanks again for the super tip !!
          • 93Oldsdroptop
            • 167
            You're welcome!
            Glad to help. My wife's doesn't leak there either for about a year now. Unfortunately, now it leaks under the oil cooler. Fix one, another springs up.
