Is crankcase evacuation possible using the exhaust on stock equipped exhaust manifold car?
something like this:
http://www.jegs.com/i/JEGS/555/52210/10002/-1
If something like the above were to be installed in the downpipe where the exhaust gas volume/speed would be maximized would it pull vacuum? The car has stock exhaust manifolds, x-over and downpipe and aft of the downpipe is a high flow 2.5" cat and full mandrel bent 2.5" catback.
The thing I like about the exhaust evacuation over the pcv is that as rpm and engine output increase so does the speed/volume of the exhaust and in theory that should create more vacuum. The pcv on the other hand, at full throttle, has no manifold vacuum and isn't doing much to evacuate the crankcase.
I've got a bit of a blow by issue. The stock pcv system isn't keeping up, there is literally no room to mount a vacuum pump unless your willing to ditch the a/c, and the electric pumps are for race duty/non continous only.
I'm stuck between a rock and a hard place. Ideally the solution to this problem is a rebuild but I'm not willing to do that yet. It otherwise runs great and I don't have the time or coin for a rebuild anytime soon.
