Did Sparkplugs and Oil Leak
  • SofaKingWeToddDid
    • Jul 2009
    • 785
    IIRC that distributor "cap" is alloy. You can't weld aluminum to cast steel.
    i what to know WHY!
    JK but why cant there be an easy permanent fix?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      There is, 3x00 swap. \thread.
      • SofaKingWeToddDid
        • Jul 2009
        • 785
        lol i want to keep my 3.4dohc!!! i like that no one likes it!
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          What I could suggest is for you to go to the local parts store and by the product called, "The Right Stuff" . It's like RTV. Now what you will need to do is prep the mating surfaces really well and lift the Distrib. "cap" up as much as possible and goop that product up in there. Then firmly press down on the cap and hold it there in place for a minute or two.
          This MIGHT work, worth a try.
          • jmgtp
            • 1219
            You can try jb weld too. It would make a mess though if you ever decided to pull the head and change the o-ring. I was lucky 120k and 18 years and it never leaked a drop. I replaced it when I had he heads off this winter and it was brittle to the point of plastic and snapped apart.
            1994 Corvette
            LT1/ZF6
            2006 Dodge Dakota 4x4
            3.7/42RLE
            • SofaKingWeToddDid
              • Jul 2009
              • 785
              #21
              jb weld, that sounds better than right stuff gasket maker. never thought of it... i really dont wanna pull the head though.
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                #22
                JB weld is not going to bond alloy and steel.
                • SofaKingWeToddDid
                  • Jul 2009
                  • 785
                  #23
                  i know its not going to permanently bond the two. im just looking for a good long term fix! thats all it takes to make me happy. so i have to put an Oring on it, have you guys ever heard of anyone using a cork gasket and looping it around there with a slit cut in it to open it up a little? does that work better?
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    #24
                    It'll work just as good as the "right stuff" . JB weld will not hold.
                    • jmgtp
                      • 1219
                      #25
                      I was just guessing when I suggested JB Weld. If the other stuff is proven to work go with that. I did mine the right way!
                      1994 Corvette
                      LT1/ZF6
                      3.7/42RLE
                      • SofaKingWeToddDid
                        • Jul 2009
                        • 785
                        #26
                        im looking for a parts car, and when i find one... that motor will get the proper treatment all the way around. ive almost given up on this motor, ill just sell it when i get the newer one up and in
                          I usually sandwich a Chevy 350 distributor gasket between some silicone on those plugs and have yet to have one leak yet. BTW, you don't want my 91, it's been rear ended and I blew the 2nd gear syncros trying to catch up to an old Supra that went flying past me. Then again, if you have ever driven a semi and can double clutch, you would do just fine :P
                          • SofaKingWeToddDid
                            • Jul 2009
                            • 785
                            #28
                            i drove a 1985 nissan pulsar for a year and had to double clutch on a couple gears too... it was rough.
                            • SofaKingWeToddDid
                              • Jul 2009
                              • 785
                              #29
                              do you have a part # for that gasket? and one from canadian tire should be good enough, right?
                              • HayesPerformance
                                • 783
                                #30
                                I'm sure I have a few.
                                You can have one if I got it..........
                                1991 Grand Prix STE
                                3.4 DOHC
                                1 of 792 Produced
                                Extensive Mods Done
                                1991 Lumina Z34
                                3.4 DOHC
                                Getrag 284 5spd
                                1 of 30
