Distributor Oil Pump Drive Plug
i think one of these weekends before winter i should check up on mine... just to make sure. lol im always paranoid about shit like that. and if it is leaking im gonna be pissed!! hahaha
Most 3.4 DOHC's I've seen that still have not touched that PCV hose have one in very bad shape, very loose or even oil soaked and swollen.
I used high pressure hose, with double high pressure clamps, and to this day, It's remained dry in the area below the lower intake.....
check that rubber PCV line too!! mine was DESTROYED! cracked and full of holes. this could not have been good for the vacuum or the oil flow.
the gasket set cost me like $50 for the stuff under the LIM, for both intakes... and the EGR. it even had a little rubber o ring for the coolant passage too! goo crappy tire.
I have seen many times too where a owner thinks that this oil plug is leaking, and instead it is the oil distribution cover on the top of the engine where the anti-flow back valve is that holds oil in the vains between it and the cam carriers.
Look for oil where the vacuum line (to the PCV) goes onto the distribution cover on the passangers side of the top of the block, under the lower intake.
I've had my fix on my car for 6 years now and no leaks. I pulled the plenum undid the clamp. lifted the plug up until it hit the rear head lip and then cleaned the hell out of it with brake cleaner. Then I slipped a brown oil proof o ring around it (measure it with calipers) . Put oil proof RTV sealant around the oring and turned it as i let it fall back in place and kept turning it until the rtv was evenly spaced around the mating surface. Let it set for half an hour and then tightned it down slowly with the clamp. zero issues...
Yeah whats the faastest way of doing it without pulling the heads?
lol whats the point in this thread anymore?? should be locked i think, the general consensus is that we should be using right stuff gasket maker, an o ring that isnt going to go brittle and dry real quick and a cork or paper gasket...
now, if a guy can get one in there without taking off the back head, without taking off any of the intakes... tell me a faster way to fix it and ill take back what i said about this thread should be locked.
seems to me the easiest way is the best way, why over complicate? take off your exhaust cross over and work from there, not the intakes... thats way too much work for an oil leak like that....
maybe ive been smoking some GOOD crack?? i dunno.
I used that new Right Stuff sealant on the o-ring and some near the top and no leaks...
we discussed this already. the original plug has to be used because if not it will interfere with the meshing of the gears... therefore the thought train should be focused on sealing the Metal #1 plug to the metal #2 block.Originally posted by Smittro View PostOkay guys just a thought here. Getting back to the freeze plug thing. How about a rubber freeze plug? They used to make them with a bolt in the center to expand the plug and make it fit real tight. I'm wondering if that would work? hmmm
Here ya go something like these:
http://cgi.ebay.com/ebaymotors/2-RUB...4506.m20.l1116
so far ive yet to hear of anything better than a cork or paper gasket with gasket maker on it.
http://cgi.ebay.com/ebaymotors/2-RUB...4506.m20.l1116Last edited by Smittro; 09-16-2009, 03:54 AM.
Yeah... You are wrong. But since we've now headed down the path of trying to separate fly shit from pepper... Viton is just a brand name for one of a family four polymers used to make "O" Ring products based upon the polymerization of the gas Tetraflouroethylene... and Dupont says you can have any color of their trademarked automotive VITON products you want...as long as its BLACK. My only point in making the comparison against the original Black O-Ring is that the Brown PTFE O Ring is NOT made of a bio-degradable, natural vulcanized rubber product and therefore is NOT subject to breaking down in the same fatal manner and causing oil leaks as a result.Originally posted by Schurkey View PostPTFE/Teflon? Really? The O-ring doesn't "feel" like teflon. Any Teflon product I have handled has been fairly firm--more like nylon than rubber. I thought the updated seal was Viton. Maybe I'm wrong.
'Nuff Said...Last edited by 60dgrzbelow0; 12-20-2009, 01:31 PM.
i dont see any of my quotes here...
if a guy can fix this in under an hour, WHO CARES ABOUT A PERMANENT FIX?!?!?! are you too much of a pussy to spend an hour or two under the hood of your car to prevent it from turning into an LQ1 cook off? the cap is easy enough to get to, and if paper and gasket maker are good enough to fix it for lets say even 100,000km... why take off the back head? i would fix it 15 more times my way before you can get it done that way.
shit why take off the intake manifolds??? more time wasting. seriously, i took off the air cleaner assy. (all of it from the TB to the snout) and from there, you are SIX (6) nuts away from the retainer clip. take off the cross over pipe. wam bam thank you ma'am the job can be fixed SO fast.
I had a good laugh at the idea of welding the hole shut.Originally posted by 60dgrzbelow0 View PostWelding a dynamic component to the block may not be such a good idea for too many reasons to mention.
PTFE/Teflon? Really? The O-ring doesn't "feel" like teflon. Any Teflon product I have handled has been fairly firm--more like nylon than rubber.Originally posted by 60dgrzbelow0 View PostAfter the late 1980's and early 1990's problems that occurred with the original "Black O-Ring" hardening, cracking and leaking, GM opted to use the "Brown" O-Ring made of PTFE (Poly-Tetra-Flouro-Ethylene) AKA "TEFLON". The engineers tested this material also for use with the pressure inner coil style seals for the main bearing journal seals. In both cases, the only problem they observed was "...the PTFE does tend to 'wander' a bit and leak on the main bearing seals after 175,000 miles, due to the effects of gravity as opposed to either chemical or thermal attacks on the seal itself."
NOTHING lasts forever. EVERYTHING fails sooner or later. The gasket-and-sealer patch method works pretty good when done correctly. I would never install the new-style O-ring without also adding the paper gasket and sealer--but that's me.Originally posted by Ghettoracer View PostI guess the only real question is: What will permanently seal it from leaking ever again? I mean you have 2 things working against that seal, heat and oil. Overtime the heat will make the o-ring to shrink and shrivel and the oil will break it down. I'm just trying to find out if there is a "permanent" fix so it doesn't leak ever.
RTV is NOT the proper chemical to use here; and sealer (of any kind) that is blorted on TOP of the parts that leak is a waste of time, money, effort, and enthusiasm.Originally posted by Ghettoracer View PostI know installing a new ring would do it but should I glob on a shit load of RTV sealant around it
You want to add a chemical sealer--fine. I did, too. The chemical sealer needs to be between the mating metal parts, not globbed on top of them. I suggest Permatex Form-A-Gasket #2 (non-hardening) or cheap Teflon pipe thread sealer--either of which is inexpensive and applies nicely to the paper gasket that should be in there as well.
Welding...DAMN, that's funny.Originally posted by Ghettoracer View Postor just make it a permanent fix and welding to the the engine.
and if a guy can get this done without taking the head off, and in under 2 hours for sure.... lol who cares about going any farther? if i had to do it again, i could probably get it done in under an hour. the first time i was pissin around with alot of pointless things, oh and i dont have ABS. i think that would make my way a little harder.... the controller is where i need to let the crossover pipe sit while disconnected.Originally posted by 1988GTU View Post'The Right Stuff' and cork gasket with very thoroughly cleaning prior to installation will likely be very adequate for keeping oil where it belongs.
