you replace a harmonic balancer in a corvair?
  • Hibson23
    • Nov 2009
    • 1
    I have a 66 Corvair with a separated harmonic balancer. There is only a few inches of clearance between the bolt and the body of the car so there is no way to get an impact wrench in there.
  • jmgtp
    • 1219
    I've removed the center bolt using a box wrench with a pipe over it and intentional interference between the pipe and the subframe of the car... then a GENTLE flick of the starter. That was something like 8 or 9 years ago... now I use the impact
    In a crunch, the above method works - for a single center bolt.
    Gotta ask since this is your first post... do you have an LQ1 in a Corvair? Must be fun!
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
