Help from DOHC guys
  • mrl390
    • Jan 2008
    • 132
    Help from DOHC guys
    I was changing my plug wires on my z34 and when I took my plenum off, the rubber sleeve that attaches the PCV valve to the plenum split in two. I went to get a new one at the auto parts store but they only sell the valve, no sleeve. Anyone know where to find one? Dealer maybe? Also, if anyone has had their plenum off, do you remember how much oil was on the inside of the plenum. Mine had enough in it to puddle up. Is that normal or is my PCV valve malfunctioning? Any input would be appreciated.
    -Matt
  • SofaKingWeToddDid
    • Jul 2009
    • 785
    last time i had mine off, it was black, but not really wet. and as for the tube, any rubber hose will work really, but mine broke too... junk yard helped me out.
    • HayesPerformance
      • 783
      Just use a high quality 3/8" hose, or thick walled silicone hose, slide it over the plastic tubing and the pcv end.
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
      • mrl390
        • Jan 2008
        • 132
        Hey, thanks guys, I got something that worked for me. I have everything back together. On a similar note, check out what I did while I had everything apart:
        -Matt
        • SofaKingWeToddDid
          • Jul 2009
          • 785
          now u just need some new bolts to hold that intake down with! it looks really good though (can you do mine too lol)
