Just have the lim welded like I do for bve, it was cake. !!!!!!
96 intake swap question? Heater core?
I would weld it but then i have to pull that shyt back out and get new intake gaskets...
Im sure a metal freeze plug pressed in will hold... they hold everywhere else on the engine...
like so:
Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
When you tap that in, it might crack that aluminum casting since its kinda thin right there. Giver it a try, it might work. I highly suggest welding it shut..... it will prevent any future failures.Lifting my front wheels, one jack at a time.
7/8" freeze plug did the trick... With a little honda bond gooped around the sides for a little extra sealing..
Here is the hose to the heater core:
All connected correctly: (I HOPE)
Shane "RedZMonte"
BTW! i Fukn hate the factory hose clamps (Ones you have to squeeze together) on all the little hard to reach hoses!!!!Shane "RedZMonte"
2.5" crush bent... it actually doesn't narrow down to bad.. one of these days i will get it redone in stainless mandrel... (getting sick of working on cars lately so won't be for a while). x-over is 2.25" mandrelShane "RedZMonte"
I'm shocked that turbo downpipe doesn't cook your ABS unit.-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostI'm shocked that turbo downpipe doesn't cook your ABS unit.
found a few wires that are starting to get a little melty lol... need more header wrap..Shane "RedZMonte"
A good coat of ceramic exhaust paint wouldn't hurt either... if you can remove it easily to do it.-60v6's 2nd Jon M.
