5 speed idle
  • 93vinx
    • 154
    5 speed idle
    my 5 speed wil not idle below 2500 when its cold, it just started to do this, after its warm it idles about 1500 and sometimes will come down to 1500 at a light, i have put on a new tps and iac , could it be intake gaskets.
    vrrrooooooooooooooooom i need new exhaust
  • 4spdz34
    • 185
    sounds like them
    • dykz34
      • Jan 2004
      • 793
      Probably intake gaskets like you mentioned or a possible vaccum leak somewhere. I'd check both.
      • Anonymous
        Mine idled at 2500 for a while when I did my headers. It was a large vacuum leak, I had forgot to attach the brake booster line
        So check your vacuum lines for sure
        • 93vinx
          • 154
          yah i went through every vaccum line, its idling even highertoday and its warmer out, if i'm driving and put it in nuetral it will idle high but if i out the clutch init dies to 1000 then jumps back up, whne i stop the idle dies down to about 2500 instead of 3000
          • Canada
            • 84
            Intake gaskets........pretty easy job to do......easier than the pushrods anyways.
            -1996 Beretta
            3400 SFI / 4T60-E
            -1991 Grand Prix SE
            3.4L DOHC / HM-284
            • 93vinx
              • 154
              did them yesterday, problem solved
