can i just line up the timing marks?
  • boostedponty
    • Jan 2010
    • 6
    hey guys so i just picked up a 95 gtp with the 3.4 DOHC i got it for a song cuz the timing belt slipped and stopped running. what I'm wondering is can i just line up the painted marks theoretically it should all line up right? sorry if its a dumb question thanks guys
    Welcome to the site!
    You can't be sure that you will get the timing right unless you do it like this. Luckily for you, you have the setup with the tapered collette and not the lock rings, making the timing job easier. This thread will tell you how to time it the correct way.
    http://60degreev6.com/content/Cam_Ti...re_Walkthrough
    • Danspeed1
      • May 2006
      • 86
      As mentioned, in short, NO. However, if you got the car for pennys its worth taking the time and doing it right.
      Just remember Cam flats on the front bank need to be the opposite of those on the rear bank... that little detail hung me up for almost 6 months.
      DG
        That and if it has ever been timed right in the past those paint marks will not be correct.
        • boostedponty
          • Jan 2010
          • 6
          thanks guys for shits today i lined up the front cams so the flats were faceing up and the painted marks are both 180 off so im glad i didnt do it like that hopefully will no if it will run 2mmrw if i get the new idlers. which was the reason it failed and shredded hopefully no bent valves crossen my fingers
            As long as it didn't let go at high RPMs you should be fine.
            • boostedponty
              • Jan 2010
              • 6
              im pretty sure it didnt the girl was just driven it normal i was told but i have another question so i took the intermediate sprocket off because a bunch of shreded belt got behind it and i didnt want it to wreck the seal so i pulled it off and pulled the pieces of belt out and the seal is slightly tore up does anyone no where i can get this seal?
                You might have to order a whole timing cover set and just use the seal.
                • boostedponty
                  • Jan 2010
                  • 6
                  well searched high and low even went to a place to match it up and they couldnt get it its a odd size apparently made by national for gm and nation wouldn't release a cross reference so i ordered one from a stealership they had a hard time finding one they have to get it from out of state so i should have the seal on fri at the latest they said so again i wait..... so anybody have any good ideas on how to put that seal in without wrecken it ? there is not enough room with a socket and hammer so im thinken bout pressing it in using the sprocket and bolt but i dont wanna risk snapen the bolt so i think i may drop the cradle on that side and work threw the fender well anybody have other thoughts?
                  • boostedponty
                    • Jan 2010
                    • 6
                    well my idea wrked with the seal i used the intermediate shaft sprocket with the bolt and some grease on it wrked perfect and after it was in as far as i could go i took it back off and used the old seal as a spacer to finish pushing it in now i still wait tho): one of the cam gear bolts was rounded off pretty bad already so i had to weld a socket to it and then order a bolt from the dealer made a pretty sweet cam gear holder in the process tho
                      Good deal I thought I had posted a reply to your question on how to install it, but either a, firefox messed up, or b, I just didn't post, lol. Not sure which... :/
                      • boostedponty
                        • Jan 2010
                        • 6
                        well got her running it runs real good alil ticking at first but it shortly went away after alil bit of running now i have to figure out why the abs and brake light is on any ideas guys? it has a firm brake pedal and the master is full and im thinken maybe rust on the axles or something the sensors for the front wheels there pretty rusty from sitten
                          Could be an iffy hub assembly. The best thing to do is find someone with an ABS scanner and have them tell you which wheel is the one throwing the ABS computer into a fit.
