ALDL connector OBD-I OR OBD-II
  • supercoop
    • Feb 2009
    • 16
    hey guys enlighten me. i have a 94 olds cutlass supreme 3.4l .the SES is on .
    and i
    dont know how to read the codes. it has a 12 pin connector under the dash.
    tried shorting the A to b terminals together. but the B terminal is missing in the plug. so nothing happens. it appears that there is an A,M an maybe a D terminal but its on the bottom row of the plug.
    ___T___
    XXX XXA
    XXD XXm
    i think the manual says its OBD-II but the man at autozone said its OBD-I because his 16 pin scanner wont plug in it.
    what im i doing wrong?
  • RedZMonte
    • Feb 2004
    • 1378
    '94 is OBD-I but is a wierd one (deemed OBD-1.5 on the boards) So you cant read it with a OBDII scanner or Jump the terminals to get the SES light to flash like OBD-I.. You must use a OBD-I scanner.
    OBD-I connection (much bigger then OBDII)
    OBD-II Connection (smaller connector, smaller pins)
    Hope this helps
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    • supercoop
      • Feb 2009
      • 16
      ahh, thankyou Shane
      would you recommend any particular scanner for this ,or are they all about the same.
      • RedZMonte
        • Feb 2004
        • 1378
        if your just reading codes and basic info they should all be about the same. some will show you what your sensors are doing, i would say that one would be worth a couple extra $$ if you buying one.. but all OBDI readers should be able to pull codes.
        S
        Shane "RedZMonte"
