excessive gas usage
  • stoneymonk
    • Mar 2009
    • 84
    Hence the reason I ask how much gas he put in his tank (besides full).
    40-45 dollars from a quarter tank to make it full,like i said earlier i go through a full tank in 2 days of driving,which is 70km times 4.then iam back to a quarter tank again.
      • 9189
      I meant gallons, not dollars. If its truly a 1/4 tank when you fill it, now we are looking at ~12.75 gallons, which works out to ~17-18mpg.
      • stoneymonk
        • Mar 2009
        • 84
        now is that good mpg,also today cleaned out maf sensor screen was black aand dirty see if that makes a difference.
          for reference:
          1995 MC/Lumina 3.4
          • stoneymonk
            • Mar 2009
            • 84
            Now thats interesting.Thanks robert and bszopi and all others for your help.Also new issue when making aa left turn theres is a vibration could that be wheel bearing?
              #21
              Replace the O2 sensor. My 3100 used to use 1/2 a tank for about a 60miles highway and about 15miles in town. After I changed it, BIG difference, more power, and the car didn't smell rich either any more.
              Don't put in a bosch O2 though. Stick with AC Delco, or Denso. http://www.sparkplugs.com had a good price on a Denso direct replacement for my car. Check there.
              Vibration: Possibly a wheel bearing, jack the car up (properly with jack stands) and grab the top and bottom of the tire, rock it and see if there is any play in the wheel bearing. It could also be a CV axle that is worn out. Or it could even be a sagging engine or transmission mount. Look how close the trans and engine is to the subframe. I had a big time shake/vibration like the tires were out of balance only at certain loads and it was my trans mount. The transmission was hitting the subframe under load.
                the ACDelco heated O2s are actually relabled Densos....
                  #23
                  Yeah I knew that the newer ones were. Much like the spark plugs are NGK. Are the original (94-95 era) O2s and plugs re-branded as well?
                    original ones? as in 15 year old O2 sensors? hell if i know, that's a long time in the supplier world. ACDelco seems to change oil filter manufacturers every couple of years, so i imagine the O2s could be the same...
                      What's the problem with Bosch O2's? I've run one for a long while without problems. Ben even tuned both of my cars with them.
                      • PCGUY112887
                        • Feb 2006
                        • 1067
                        #26
                        A number of people have had them fail fairly quickly. My Bosch lasted about a year then I started to get an SES light for improper O2 heating, swapped with a Denso and it's been fine since.
                        SpudFiles
                        Theopia
                        Enjoy life online.
                          Is this just a HO2 thing? Mine's a one wire... OBD1 ftw!
                            heated O2s are supposed to last longer than a non-heated....
                            there is at least one OBD1 application i can think of that came with heated O2s from the factory... and it involves a 4.3 and a hairdryer...
                            • Weatheralls Auto
                              Spinning out of control
                              • Dec 2009
                              • 536
                              #29
                              Older AcDelco HO2s' were Bosch I beleive.
                              Had tons of issues with them especially with the MMT and other crap in our fuel here in Canada.
                              As of April 2
                              Engine: 2006 SV6 3500 LX9
                              Trans: 2002 Getrag F23 5speed
                              Injectors: #36 GTPs
                              TB: 65mm TCE
                              Maf: 1999 3400 Montana.
                              Beverages: Ice Cold CANADIAN.
                              • stoneymonk
                                • Mar 2009
                                • 84
                                #30
                                Thanks for the info,come to think of it got really good mileage in the summer weather also the exhaust does smell rich,wiil change and see what happens,on a 95 i think there is only one o2 sensor?.
