EGR tube Fix
  • 93-Z34
    • Jan 2010
    • 14
    EGR tube Fix
    Well I have been trying to find an EGR tube for my 93 Z34, but no luck. So I decided to make one, the only reason I don’t delete it is because of emission, I have to go through. So I thought I would share it, in case anybody else needs one and how to fix it.
    Here is my tube.
    I cut the ends off.
    just other look.
    Went out an bought a new Gas Range 3/8 hose (stainless steel painted yellow)
    $10.00 bucks from Home Depot.
    Cut the ends off of it.
    Then attached them to my old EGR tube ends.
    Just need to get it brazed and good to go, I'll post a picture of it after it's brazed and installed.
    you can see the thinkness is pretty close.
    That also looks like a flared end on the gas hose too, so it might be a little thinner there than the rest of the hose. It looks good, I just hope the gas hose holds up to exhaust temps, which I imagine with the low flow there that it would.
    • 93-Z34
      • Jan 2010
      • 14
      Yeah it is the flare end, so it would be a little thinner, both lines are stainless so it should hold, don't really know what the temper temp of the gas range hose is, but I guess I find out.
      • 93-Z34
        • Jan 2010
        • 14
        So here it is after brazing, It held up to the brazing torch pretty good, so I think it will last awhile in the motor.
        • RedZMonte
          • Feb 2004
          • 1378
          clever... keep us posted if it holds up.
          S
          Shane "RedZMonte"
          1992 Lumina Z34-VIRGIN (RIP)
          1992 L67 Lumina Z34 (SOLD)
          1990 Turbo Grand Prix (SOLD)
          • neo71665
            its this big
            • Oct 2005
            • 361
            I'd take a wire brush to that yellow paint before putting it on the car. I'm sure thats not gonna be high temp.
            87 3.4 4x4 blazer
            • 93-Z34
              • Jan 2010
              • 14
              Yeah, that probably would have been a good idea, like installing the heat shield before brazing it (lol). But I cut it in half (shield) and wrapped around the tube and put a hose clamp on it. It fits perfect, I wil post a picture later.
              Now I have a new problem, No Spark on none of the plugs, I have fuel pressure, I can hear the pump prime and the FP gauge tells me its pushing 42PSI but it won’t hold it, bleeds off to 10PSI after cranking. The car ran fine before we pulled the motor, strong, no misses. The motor was pulled to change the oil pan gasket and rear main, while we were in there I changed the front pump seal on the tranny too, now it won’t start. I have been doing some reading on here, I’m going to look into the CPS but would like your guys opinion on where else to check next. Can I check the CPS, while its in the car, pull the plug on modular, hook up a DMM (multimeter) have somebody crank the motor and see a response, it’s a magnetic pick up so I should see voltage, right?
              • 93-Z34
                • Jan 2010
                • 14
                That was it !!
                It's Alive,
                button it tomorrow, take it for a ride, hit the emission station.
                Thxs
                • 93-Z34
                  • Jan 2010
                  • 14
                  Just and update: car past with flying colors. Tube is holding strong so far.
                  • DefEddie
                    • Aug 2009
                    • 194
                    Sweet fix,I love walking hardware stores for stuff I could use for other things.
                    It's like a junkyard but stuff is cheaper and new.
                    • IsaacHayes
                      Mr. Orange.
                      • Apr 2006
                      • 6030
                      Clever. Being a 93 if you had tuning equipment you could have plugged it and left the old stuff there to make it look like it was hooked up and disabled it in the tune.. hehehehe.
                      • fastback4
                        • Feb 2009
                        • 175
                        93Z34.....Your my new f++king hero Dude!
                        • DefEddie
                          • Aug 2009
                          • 194
                          If anybody needs one of these things i'm pretty sure I have at least two laying around.
                          • 93-Z34
                            • Jan 2010
                            • 14
                            No problem
                            Now you chime in.
                            • 93-Z34
                              • Jan 2010
                              • 14
                              Still holding strong!!!!!!!!!!!!!!
