Factory Manual Question
  • Jogasz28
    • Dec 2006
    • 132
    I have a 1995 Monte Carlo Factory Manual that I originally bought for my 1995 Monte Carlo Z34. I see that it also has the 3100 engine in it.
    As I have to do the intake/head gaskets on my 1999 MC, can I use the '95 manual for direction, torque specs, etc.?
    The '95 Factory Manual shows the 3100 as an "M" engine.
    I'm still trying to figure out if my '99 is an M or a J.
    TIA,
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    the updated torque specs and procedures will make a more reliable engine, though i'm not sure when they came out. i believe they are somewhere on the site, if not i'll post them for you.
    i highly doubt you have a J motor, only the n-cars seemed to have gotten them in 1999.
      • 9191
      http://60degreev6.com/content/3100_E...Specifications
      To determine if you have a VIN M or J, just look at the plenum - if it has ribs and a small 3100SFI, then it is VIN M. If it is smooth with the exception of large 3100SFI, then it is VIN J. I agree though, you probably have a VIN M.
      • Jogasz28
        • Dec 2006
        • 132
        Thanks.
        It's got the ribs and the 3100 SFI, so it's an M.
        So can I use my '95 Factory Manual which has the 3100 "M" in it, and
        then use the updated Torque Specs?
        jogasz28
        ______________
        '68 RS Camaro,
        '99 Monte Carlo LS
