Ignition key lock cylinder 95 lumina
  • stoneymonk
    • Mar 2009
    • 84
    my ignition cylinder seems to be loose its sticks out about a 1/4 if an inch from the column housing and seems to be spring loaded is this normal.
  • 86FieroSEv6
    • Feb 2010
    • 527
    Yes, the lock cylinder does have a spring action, but it should only push in about an eighth of an inch to rotate.
    • stoneymonk
      • Mar 2009
      • 84
      tks fiero thought i have to re and re lock cylinder,also do u know how to bypass the vats system
