tps sensor
  • stoneymonk
    • Mar 2009
    • 84
    tps sensor
    how do u install a tps sensor on a 95 lumina.Pic would be great Thanks all.
  • RedZMonte
    • Feb 2004
    • 1378
    I assume your refering to the Throttle Possition Sensor.... Sensor
    the TPS is right on the side of the intake manifold on the other side of the TB to where the throttle cables connect. IIRC they are 2 smaller torques screw holding it in. not hard to do.
    you can kind of see it in this pic.... The sensor on the top is the IAC the one just below it to the right is the TPS.
    2 screws holding it in
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      i know the IAC used T20 screws... i imagine the TPS would as well.
      • stoneymonk
        • Mar 2009
        • 84
        Thanks Guys is there any special way to installing it or does it just go in the way it came out and replug?Reaso for asking is that the pics of the part i seen has two plastic tabs that are parallel to each other does the throttle shaft goes between them or lines up to the tabs?
          • 9187
          The throttle shaft will actually be D-shaped at the end, and the inside of the TPS is also D-shaped. Therefore, the TPS will only fit one way. There is probably 1 tab on it, which will fit a hole in the TB to otherwise line it up.
          But, it really is just an undo and replace. If you can change the oil in your car, you can swap out the TPS.
          Sent from my Droid using Tapatalk
          • Teardrop
            • Sep 2010
            • 24
            With most throttle bodies, the TPS will be directly on the other side.
            Hell if you can change wiper blades, then a TPS is not half as difficult.
            Just make sure that it is the actual bad component, cause other problems can cause the ECM to think the TPS is bad.
            1994 Grand Prix GTP 3.4 DOHC
              Agreed. I know it's a different part, but years ago I got a bad IAC code when I had a vacuum leak from intake gaskets that were boarding the failboat.
              • stoneymonk
                • Mar 2009
                • 84
                Thanks for all your inputs guys,wiil be doing a re and re this weekend will post results
                • stoneymonk
                  • Mar 2009
                  • 84
                  All went well with the tps install,currently the problems are when after car gets hot and shutdown go to restart the battery is dead,starts with a boost then it bogs like starving for fuel.When running cold to operating temp lots of power,have checked all fuses all good,checked volts at battery 12-13 not running 14-15 running,can hear the fuel pump buzz when key is on on position,been told could be egr?,also where is the fuel pressure regulator located.Thanks Guys.
                  • RedZMonte
                    • Feb 2004
                    • 1378
                    i would put a Fuel pressure gauge on the rail when it acts up, also if you pull the vac line off the FPR and see if its pissing out gas in the FPR. if the battery is dead when it dies then i doubt its a fuel problem but always good to check fuel and spark. pull egr and clean it... seen it do funny stuff but wont think that is the problem. The FPR is under the intake manifold.... you will see it on the rail, i did a '96 intake swap so my fpr is in a different location.
                    S
                    Shane "RedZMonte"
                    • stoneymonk
                      • Mar 2009
                      • 84
                      Thanks Redz,already cleaned the egr,dont have a fp gage,can i see the fpr without pulling the intake?,also where is the map sensor it near the firewall with a elictrical plug and 2 vac lines?As for the car needing a boost after getting hot any ideas,when cold i can star the car at least 10 times with no problems.
                      • RedZMonte
                        • Feb 2004
                        • 1378
                        I will look at my old fuel rail and see where it is located... IIRC the FPR is under the intake manifold you MAY be able to see it but cant access it. if its a 1995 then you have a MAF and NO map. I think you are refering to the Evap sollinoid (couple wires and couple vac lines on the back side of intake between firewall). Honestly it could be many things.... just need to start eliminating... when my fuel pump was going out it would fail when hot work when cold. parts store may rent a guage if not they are cheap to buy.
                        S
                        Shane "RedZMonte"
                        • stoneymonk
                          • Mar 2009
                          • 84
                          Thanks Redz that is what i was referring too.
                            I would also check your battery cables for corrosion in the insulation. Also have you had the battery load tested?
                            • stoneymonk
                              • Mar 2009
                              • 84
                              Changed out the battery seems to be starting fine,wiil test drive and post results,also cleane out one ground on the rad support cant get a wrench on the engine ground but sprayed with brake clean to remove all the grease.Is there any other ground locations?.
