ok heres the situation i rebuilt my engine and dropped it back in the car and hooked everything up how i should have or so i thought the engine cranks but is slow is there any common problems with these cars not starting after a rebuild and what r some things i should check
crank no start need help
Tags: None
I would make sure grounds and the area where the starter meets the block are clean and free of paint and oil and go from there.-60v6's 2nd Jon M.
Also maybe try it without the accessory belt. I know someone with a Lumina (3x00) that the AC compressor froze and it made the car act like a bad battery or starter. Maybe even toss a ratchet on the crank pulley and see if it's harder to turn over by hand then it should be.-60v6's 2nd Jon M.
well it was a little stiff while i was tring to bolt the tc to the flexplate but everything was on the engine at the time so that could explain that but idk i have an oil leak behind my oil cooler b4 i can fix my no start and the ac compressor would only matter if it was a variable displacement compressor and not a on/off clutch style. unless your friend compressor clutch siezedOriginally posted by pocket-rocket View PostAlso maybe try it without the accessory belt. I know someone with a Lumina (3x00) that the AC compressor froze and it made the car act like a bad battery or starter. Maybe even toss a ratchet on the crank pulley and see if it's harder to turn over by hand then it should be.
I think it was the bearings for the pulley, so in theory the actual compressor itself could have still been fine.-60v6's 2nd Jon M.
