Timing Belt Question
  • Dan94Z34
    • Jun 2004
    • 5
    I am replacing my timing belt in my 94 Z-34. I got the motor tore down and am in the process of putting the new belt on. For the life of me I can't get the cam sprockets loose. After Put the new belt on and the belt looks like it locked in to the sprocket groves. Why do I need to loosen the Cam sprockets? It looks like I can replace the belts with out loosening them.
  • Dan94Z34
    • Jun 2004
    • 5
    ok, So I can't get the belt on right with out loosening them. Where do I get a sprocket hold down? Or what can I use in place of a sprocket hold down?
      Check on Ebay for the entire timing belt tool kit made by Kent-Moore.
      • d.o.h.c
        • Jun 2004
        • 981
        in order to get the pulleys loose or off you have to use a rubber hammer and tap them off. thats how it is on the 94+
        • RednBlack
          Wood Hippie
          • Mar 2004
          • 2795
          I've read that a lot of people on this website have made their own.
          • 93vinx
            • 154
            i made my own outta 3/4 by 1/2 square steel
            vrrrooooooooooooooooom i need new exhaust
            • Lyle's GTP
              • Jan 2004
              • 1345
              Made mine with 3/4" X 3" Cold drawn flat bar. With that size you can use an intake manifold bolt. I just had a piece laying around. Plus, I wanted no deflection what-so-ever.
              Lyle
