last nite i was just driving around breaking in the new motor when i noiticed my alt wasn't charging, i swore then started heading home, in a few minutes it came back on and and did this several times more. the gaugae works, it never dropped below 12 volts, optima battery in back,
i checked the battery wires all are tight, today i checked the wire on the back of the alt , tight also, starter wires are tight too, the car cranks kinda hard but starts good. befor the new motor the alternator went out, or maybe so i thought, but now it seems to be doing the same, the part i do not get is the battery light ( the little battery) doesn't come on and from whati under stand this only happens if the regulator goes bad in some certain way. what else could cause my problem?
Just look at it and forget about it being " just an altenator" You are into a unique situation here. The dealers charge 6 shop hours to do this job. Follow this sites directions. You can do it. It depends on your " bitch factor " tolerance. You can get thew fucker out the back ifv you drop the cradle down about a foot or so.( Not Recommended tho). Need directions just ask. Everyone here has changed one or two.
