Ignition woes; spark arcing to anything around
  • grandprix34
    • 168
    I spent the most part of today checking my DOHC's ignition system. It seems that when I pull the #6 plug in the dark, almost the whole length of the wire lights up like a x-mas tree. When I pull any other wire, the wires also arc with the block or any grounded source around.
    One thing that troubles me is that the #6 plug wire, when pulled, causes more of the arcing around the lower coil portion.
    Can anyone shed some light to this? Could this be the cause of my KNOCK RETARD being so high??
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
  • Rhedalert
    Dr. Feelgood
    • 1574
    Times call for new spark plug wires.
    Brian
    3400 SFI V6, 4T60e
    • grandprix34
      • 168
      what?! Damn these puppies aren't that old, AND they're Taylor 8mm wires!!! BAH! oh well, Murphy law at its best with me this week....
      by the way, any chance the prob is with the coil towers being cracked??
      - Hi-Flo Cat
      • Rhedalert
        Dr. Feelgood
        • 1574
        of course, if your coils are cracked or damaged that's a possibility!
        Brian
        3400 SFI V6, 4T60e
        • gpse3400
          • 1460
          Ain't it the truth.......Of course destroying pushrods has been a past time of the Island as well!!!
          Lorenzo
          • grandprix34
            • 168
            when attached to the plug they dont leak though...only when pulled. What gives? Can this affect me at high RPM's, say a 1/4 mile run? I got a meet the 16th so I am doing as much as possible to the car.
            - Hi-Flo Cat
