Rear exhaust manifold gasket replacement
  • farley463
    • Apr 2013
    • 50
    Well guys I did my head gaskets a few weeks ago on my dohc, and for the most part everything went well, but without even thinking, I ended up reusing the old exhaust manifold gaskets ON THE BACK SIDE! Well, now I have a real loud exhaust tick. I'm trying to figure out if I can do it up on jackstands from underneath, or should I pull the cam cover. It looks like I might have enough room if I pull the downpipe from the back of the manifold. What do you guys think? Believe me, I know I'm a dumbass lol...
    -1997 Monte Carlo Z34. 1997 LQ1 with 95 cams, paired with a freshly rebuilt 4t65e. Still working out a few problems but its good to have it back after 4 months!
  • walterdude
    Destroyer Of ALL THINGS!!
    • Feb 2006
    • 265
    If you pull the dog-bone engine mount, the one that goes from the head to the radiator support and rock the engine forward with a come-along you can gain quite a bit of room to get at the rear of the engine.....
    Good luck!!!
    Tom...
      You could also drop the rear of the sub-frame down a couple inches as well, but don't go any farther than that or you will have fun hooking the slip joint for the steering back up.
      • farley463
        • Apr 2013
        • 50
        Those are good ideas. As long as it saves me from pulling the cam carrier I can dig it. Lol I dunno about dropping my subframe cause my underbody is a bit rough. Ill see what I can do and keep yall updated
