'93 oil cooler hose
  • chriswhewell
    • Aug 2012
    • 12
    '93 oil cooler hose
    On my '93 Cutlass, there's a short hose that goes from the engine block to the oil cooler.
    Any idea of a parts supplier that sells such a hose ? The usual parts stores I checked don't have it thanks!
    Probably dealer only item, and being a 93, probably discontinued... Best bet is to go to an auto parts store and have them match up the bend if any on it and diameter with something they have that may be too long, or have an extra bend it in and just cut it to fit.
    • chriswhewell
      • Aug 2012
      • 12
      Thanks alot, did that, cut the new hose and it worked perfectly
      • Schurkey
        • Apr 2007
        • 339
        Post the part number of the sacrificial hose.
        • chriswhewell
          • Aug 2012
          • 12
          Gates 18799.
          But now I'm f--d in another way..... the draincock on the new radiator I put in last year.... threads are stripped inside the rad. I was real careful with them when I put the brand new rad in last year, I know about these plastic pos's. Other than a new radiator, anyone know a way to remedy stripped internal plastic threads or otherwise seal the drain on that rad ? dangit
          Edit: here was the fix for the second problem, thread insert included: http://www.autozone.com/autozone/par...fier=1049_0_0_
            I think www.rockauto.com sells just end tanks, but I bet that's a blast changing them. Where are you located? Maybe someone might be local to you that would be willing to deal.
            • chriswhewell
              • Aug 2012
              • 12
              Austin. But its all fixed now, thanks.
                NP. You get stuff taken care of way faster than I do, lol.
                • chriswhewell
                  • Aug 2012
                  • 12
                  Its my son's car, that hose was just old and cracked way up there. Towed him home last week on the trailer and the fuel pump went out in the truck but not totally, it still pissed enough gas to enable us to go 35 mph with a lot of jerking and frustration for about 100 miles, but at least we made it back! I was glad we re-located the coils and module last year, its tight down in there.
                    Yeah, I've never been a fan of the stock coil location on them. Mine are going to the stock location for the 96/97 DOHC when my car gets an engine again. I like the thought of up on top in the rear vs under an exhaust manifold, lol.
                    • chriswhewell
                      • Aug 2012
                      • 12
                      indeed. The stock location has too much heat and ignition modules don't fare well with heat. I put the coils up on a ledge up under the fusebox
