Hey ya'all I'm going to put new injectors in the 3.4 dohc. Is there a gasket set that's recommended ? thanks a bunch
Injector swap
Tags: None
Just the plenum to LIM gasket if you mess it up. If you're careful taking it apart and don't tear it you should be ok to reuse it. I would probably be wise to get new injector o-rings for the new injectors, and give them a light coat of oil to help them slide into the rail and LIM easier. If you don't know when the last time the LIM to head gaskets have been changed it wouldn't be a bad idea to change them if it's a 91-95 intake.-60v6's 2nd Jon M.
