3.4l knock sensor location
  • thelovebot
    • Nov 2013
    • 4
    Hi, I have a 1993 cutlass supreme with the 3.4l dohc motor in it. Does anybody know where the knock sensor is on it? The service manual has never helped me with this car at all. Thanks.
    It is on the back of the engine in about the middle of the block. If you have an auto you would probably be able to get at it from behind the alt. If you have a manual it's easy street from under the car.
    • Schurkey
      • Apr 2007
      • 339
      It threads into a blind hole in the block, so you can unscrew it without losing any coolant. The new one installs with a specified torque, and being accurate there is important.
      • thelovebot
        • Nov 2013
        • 4
        thanks schurkey and pocket rocket. just to be clear, rocket, do i have to remove the alternator itself, or is it possible for me to work my arm up behind it (i've experienced firsthand the horror of replacing this alternator).
          You can go either route, but removing the alternator will make it easier to access.
          Heed schurkeys warning on the torque spec. Too tight and the new sensor will be too sensitive, too loose and it won't be sensitive enough.
          • Schurkey
            • Apr 2007
            • 339
            I can't help you on the accessibility issue, I played with the knock sensor AFTER removing the rear head due to failed head gasket. Alternator, block heater, and knock sensor were therefore EXTREMELY easy to access.
            • thelovebot
              • Nov 2013
              • 4
              Do you think that a bad knock sensor/circuit could cause the engine to run roughly at idle and stall out? I've had that happen a few times, with only a DTC 43 (knock sensor circuit) stored. Wet weather seems to worsen the problem. Just replaced the idle air control valve very recently.
                My first guess would say no. I would look at normal maintenance items like plugs and wires first off, especially the wires given wet weather effects.
