help! need to replace fuel injectors?
  • mickle_70
    • Jun 2004
    • 6
    I have a 91 Z34 and the injectors are bad. will only 91>93 injectors work in My car or will any 3.4 injectors work in it too? , also replacing fuel pump too, Is their a up grade factory pump that i can put in there too
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    on the fuel pump i think granatelli make a high performance fuel pump but on the application it says gm cars same for eblebrock(pn 1733) get in touch with them and find out. they will be about the same price as a stock fuel pump i think.
    are all 6 of your injectors bad? i have 4 94 dohc injectors laying around that i could sell u for 20 bucks. they worked great when pulled. these engines use 23 lb injectors the 3.4 pushrods use 17 i think. and i have heard the dohc injectors have a specific spray pattern not sure on that though.
    • Anonymous
      I think he means any 3.4 DOHC, in which case the answer is yes they will work just fine.
      Secondly, an aftermarket fuel pump is a waste of money if you are under 300hp, of which I'm assuming you are considering you are using stock injectors. A bigger fuel pump will do nothing for performance.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        u are right it prolly won't do anything but they cost about the same as a stock replacement and he will have it there in case he decides to make some power like going turbo/supercharged. or he can get a 96 rail and jack up the fuel pressure a few pounds safely.
        • PlatinumZ34
          • 232
          go with the 96-97 3.4dohc injectors... from what everyone says on here they're quieter.
          2001 Mustang GT
          1991 5spd Lumina Z34 - Dead
          1947 4spd International - Dead... Reincarnation pending.. getting close now .
          • mickle_70
            • Jun 2004
            • 6
            Will the 96>97 drop right in to my car its a 91 ? I talked with some one at RC.. a injector place ,and he said because mine are leaking down . they probably have dirt in them so try some injection cleaner first he said its hard for the valves and needles to where out ..?does that sound right? My Z has 225,000 on it...
            • Anonymous
              225000 miles???
              Wow I didn't know a 3.4L could still run after 150k
              Yah the 96s are MUCH quieter and will drop right in. Dude you really otta search, we had a discussion about this just a few days ago
